--- title: "system.tag.browseTagsSimple" description: "Returns a sorted array of tags from a specific folder." --- # system.tag.browseTagsSimple > Returns a sorted array of tags from a specific folder. ​ This function is used in **Python Scripting**. ​ ## Description Returns a sorted array of tags from a specific folder. ​ ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ​ ## Syntax `system.tag.browseTagsSimple(parentPath, sort)` ​ ### Parameters | Type | Parameter | Description | |---|---|---| | String | `parentPath` | The parent folder path. Leave blank for the root folder. **Note**: You can specify the tag provider name in square brackets at the beginning of the parentPath string. For example, `[myTagProvider]MyTagsFolder`. If the tag provider name is left off then the project default provider will be used. | | String | `sort` | Sets the sort order, possible values are ASC and DESC. | ### Returns **BrowseTag[]** - An array of BrowseTag. BrowseTag has the following variables: name, path, fullPath, type, dataType, and the following functions: isFolder(), isUDT(), isOPC(), isMemory(), isExpression(), isQuery(). ### Scope All ​ :::caution If called in the Gateway scope, a tag provider must be specified. ::: ​ ## Code Examples ​ ```python title="Example #1" # This script will print out the names of all tags and the tag type tags = system.tag.browseTagsSimple("", "ASC") for tag in tags: print "Name:",tag.name, "\tType:", tag.dataType ```
