--- title: "system.sfc.startChart" description: "Starts a new instance of a chart." --- # system.sfc.startChart > Starts a new instance of a chart. This function is used in **Python Scripting**. ## Description Starts a new instance of a chart. The chart must be set to "Callable" execution mode. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.startChart(path, arguments)` ### Parameters |Type|Parameter|Description| |--|--|--| |String|`path` |The path to the chart, for example "ChartFolder/ChartName".| |Dictionary|`arguments` |A dictionary of arguments. Each key-value pair in the dictionary becomes a variable in the chart scope and will override any default.| ### Returns **String** - The unique ID of this chart. ### Scope All ## Code Examples ```python title="Code Snippet" # The following will start an SFC with a dictionary of values to use inside the chart args= {"var1":10, "Var2":15,"Var3":1} path = "ChartFolder/ChartName" sfcID = system.sfc.startChart(path, args) ```
