--- title: "system.sfc.setVariables" description: "Sets any number of variables inside a currently running chart." --- # system.sfc.setVariables > Sets any number of variables inside a currently running chart. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.setVariables(instanceId, [stepId], variableMap)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`instanceId`| The instance identifier of the chart.| |String |`stepId`| The id for a step inside of a chart. If omitted the function will target a chart scoped variable. [Optional]| |PyObject |`variablesMap` | A dictionary containing the name:value pairs of the variables to set.| ### Returns Nothing ### Scope All :::note Omitting the **stepId** parameter will cause the function to target a chart scoped variable. If the variable is persistent to the whole chart, or used in multiple different steps, then this parameter should be omitted. If a stepId parameter is used, then the function will target a step scoped variable. **The step associated with the stepId must be the currently active step**. ::: ## Code Examples ```python title="Code Snippet" # Get the instance ID from the selected chart on a SFC Monitor component id = event.source.parent.getComponent('SFC Monitor').instanceId # Create a Python dictionary of values. This example assumes there are variables on the # chart named chartParam and counter. The script will set these to 1, and 0 respectively dict = {"chartParam":1, "counter":0} # Set the variables on the chart system.sfc.setVariables( id, dict) ```
