--- title: "system.sfc.setVariable" description: "Sets a variable inside a currently running chart." --- # system.sfc.setVariable > Sets a variable inside a currently running chart. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.setVariable(instanceId, [stepId], variableName, variableValue)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`instanceId` | The instance identifier of the chart.| |String| `stepId`| The id for a step inside of a chart. If omitted the function will target a chart scoped variable. [Optional]| |String |`variableName`| The name of the variable to set.| |Object| `variableValue` | The value for the variable to be set to.| ### Returns Nothing ### Scope All :::note Omitting the **stepId** parameter will cause the function to target a chart scoped variable. If the variable is persistent to the whole chart, or used in multiple different steps, then this parameter should be omitted. If a stepId parameter is used, then the function will target a step scoped variable. **The step associated with the stepId must be the currently active step**. ::: ## Code Examples ```python title="Code Snippet" # The following passes the chart instance ID and step ID to a client message Handler. The message handler can then wait # for user input, and then write back to the step variables. # The example assumes there is a chart scoped variable called confirmEndchart, and a step scoped variable called "messageSent". # Get the instanceId of the current chart chartID = chart.get("instanceId") # Get the id of the step stepID = step.get("id") # Create a payload to pass to the client. # Include the instanceId and stepId so the script from the message handler knows which # chart and step to write to payload = {"chartID" : chartID, "stepID" : stepID} # Send the message system.util.sendMessage(project = "SFC", messageHandler = "SFCMessage", payload = payload ############ # The following script would be placed on a client message handler. This receives the payload, # and sets a variable on either the chart or step depending on user selection # Read items out of the payload id = payload['chartID'] stepId = payload['stepID'] # Ask the user to end the chart if system.gui.confirm("Would you like to end the process"): #If yes, end the chart. confirmEndChart is chart scoped, so only 3 parameters are passed system.sfc.setVariable(id,"confirmEndChart",True) else: #If no, reset the step.messageSent variable so that the user will be prompted again #messageSent is step scoped, so 4 parameters are passed system.sfc.setVariable(id,stepId,"messageSent",False) ```
