--- title: "system.sfc.redundantCheckpoint" description: "Synchronizes chart and step variables of the specified chart instance across a redundant cluster, allowing the chart instance to continue where it left off if a redundant failover occurs." --- # system.sfc.redundantCheckpoint > Synchronizes chart and step variables of the specified chart instance across a redundant cluster, allowing the chart instance to continue where it left off if a redundant failover occurs. This function is used in **Python Scripting**. ## Description Synchronizes chart and step variables of the specified chart instance across a redundant cluster, allowing the chart instance to continue where it left off if a redundant failover occurs. Check out [redundancy sync](sequential-function-charts\SFC-basics\chart-properties.md#redundancy-sync) for more information. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.redundantCheckpoint(instanceId)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`instanceId` |The instance identifier of the chart.| ### Returns Nothing ### Scope All
