--- title: "system.sfc" --- # system.sfc > The following functions give you access to interact with the SFCs in the Gateway. ## SFC Functions ### Functions by Scope ## Chart Scope Variables :::note Certain chart scoped variables may interfere with the internal functions of the chart. For example, creating a variable like chart.values will conflict with a pyDictionary's values() method and therefore the chart will show an error. Since SFC charts use Python Dictionaries to manage chart scoped variables the methods associated with Python Dictionary's act like reserved words. ::: There are a number of built-in variables maintained by the SFC engine that can be read through the `chart` scope. | Variable Name | Description | |---|---| | chart.instanceId | The string UUID of the running chart instance. | | chart.startTime | A `java.util.Date` object that indicates when the chart instance started running. | | chart.runningTime | An integer representing the number of seconds the chart has been running for. | | chart.parent | The chart scope of the enclosing chart (if any). Null if this chart was not executed as part of an enclosing step. |
