--- title: "system.serial.writeBytes" description: "Write a byte[] to a serial port." --- # system.serial.writeBytes > Write a byte[] to a serial port. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.serial.writeBytes(port, toWrite)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `port` | The previously configured serial port to use.| |byte[]| `toWrite` | The byte[] to write.| ### Returns Nothing ### Scope All
