--- title: "system.serial.readLine" description: "Attempts to read a line from a serial port." --- # system.serial.readLine > Attempts to read a line from a serial port. This function is used in **Python Scripting**. ## Description Attempts to read a line from a serial port. A "line" is considered to be terminated by either a line feed ('\n'), a carriage return ('\r'), or a carriage return followed immediately by a line feed. The function will wait until the timeout period for a terminator. If the timeout is reached before the line is properly terminated, then the buffer will be dumped, possibly resulting in data loss. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.serial.readLine(port [, timeout] [, encoding])` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`port` |The previously configured serial port to use.| |int| `timeout`| Maximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional]| |String |`encoding` | The String encoding to use. Default is UTF8. [optional]| ### Returns **String** - A line of text. ### Scope All
