--- title: "system.serial.readBytes" description: "Read numberOfBytes bytes from a serial port." --- # system.serial.readBytes > Read numberOfBytes bytes from a serial port. This function is used in **Python Scripting**. ## Description Read `numberOfBytes` bytes from a serial port. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.serial.readBytes(port, numberOfBytes [, timeout])` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`port` | The previously configured serial port to use.| |int |`numberOfBytes` | The number of bytes to read.| |int |`timeout` | Maximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional]| ### Returns **byte[]** - A byte[] containing bytes read from the serial port. ### Scope All
