--- title: "system.serial.openSerialPort" description: "Opens a previously configured serial port for use." --- # system.serial.openSerialPort > Opens a previously configured serial port for use. This function is used in **Python Scripting**. ## Description Opens a previously configured serial port for use. Will throw an exception if the serial port cannot be opened. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.serial.openSerialPort(port)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`port` |The name of the serial port, e.g., "COM1" or "dev/ttyS0".| ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" # Assuming "COM1" has already been configured with system.serial.configureSerialPort, this would open the port system.serial.openSerialPort("COM1") ```
