--- title: "system.serial.configureSerialPort" description: "Configure a serial port for use in a later call." --- # system.serial.configureSerialPort > Configure a serial port for use in a later call. This function is used in **Python Scripting**. ## Description Configure a serial port for use in a later call. This only needs to be done once unless the configuration has changed after the initial call. All access to constants must be prefixed by " system.serial. ". ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax :::note This function accepts [keyword arguments](scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.serial.configureSerialPort( port, bitRate, dataBits, handshake, hardwareFlowControl, parity, stopBits)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`port` | The name of the serial port, e.g., "COM1" or "/dev/ttyS0". This parameter is required.| |Integer |`bitRate` | Configure the bit rate.Valid values are defined by the following constants: BIT_RATE_110, BIT_RATE_150, BIT_RATE_300, BIT_RATE_600, BIT_RATE_1200, BIT_RATE_2400, BIT_RATE_4800, BIT_RATE_9600, BIT_RATE_19200, BIT_RATE_38400, BIT_RATE_57600, BIT_RATE_115200, BIT_RATE_230400, BIT_RATE_460800, BIT_RATE_921600.| |Integer |`dataBits` | Configure the data bits.Valid values are defined by the following constants: DATA_BITS_5, DATA_BITS_6, DATA_BITS_7, DATA_BITS_8.| |Integer |`handshake` | Configure the handshake.Valid values are defined by the following constants: HANDSHAKE_CTS_DTR, HANDSHAKE_CTS_RTS, HANDSHAKE_DSR_DTR, HANDSHAKE_HARD_IN, HANDSHAKE_HARD_OUT, HANDSHAKE_NONE, HANDSHAKE_SOFT_IN, HANDSHAKE_SOFT_OUT, HANDSHAKE_SPLIT_MASK, HANDSHAKE_XON_XOFF.| |Boolean |`hardwareFlowControl` | Configure hardware flow control: On or off.| |Integer |`parity` | Configure parity.Valid values are defined by the following constants: PARITY_EVEN, PARITY_ODD, PARITY_MARK, PARITY_SPACE, PARITY_NONE.| |Integer |`stopBits` | Configure stop bits.Valid values are defined by the following constants: STOP_BITS_1, STOP_BITS_2.| ### Returns **SerialConfigurator** - A SerialConfigurator that can be used to configure the serial port instead of or in addition to the given keyword arguments. ### Scope All ## Code Examples ```python title="Example #1" # Configure a serial port using keyword args. # The "port" keyword is mandatory. system.serial.configureSerialPort(\ port="COM1",\ bitRate=system.serial.BIT_RATE_9600,\ dataBits=system.serial.DATA_BITS_8,\ handshake=system.serial.HANDSHAKE_NONE,\ hardwareFlowControl=False,\ parity=system.serial.PARITY_NONE,\ stopBits=system.serial.STOP_BITS_1) ``` ```python title="Example #2" # Configure a serial port using a SerialConfigurator (returned by configureSerialPort()): system.serial.configureSerialPort("COM1")\ .setBitRate(system.serial.BIT_RATE_9600)\ .setDataBits(system.serial.DATA_BITS_8)\ .setHandshake(system.serial.HANDSHAKE_NONE)\ .setHardwareFlowControl(False)\ .setParity(system.serial.PARITY_NONE)\ .setStopBits(system.serial.STOP_BITS_1) ```
