--- title: "system.serial.closeSerialPort" description: "Closes a previously opened serial port." --- # system.serial.closeSerialPort > Closes a previously opened serial port. This function is used in **Python Scripting**. ## Description Closes a previously opened serial port. Returns without doing anything if the named serial port is not currently open. Will throw an exception if the port is open and cannot be closed. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.serial.closeSerialPort(port)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `port` | The name of the serial port, e.g., "COM1" or "dev/ttyS0".| ### Returns Nothing ### Scope All
