--- title: "system.secsgem.startSimEventRun" description: "Starts a configured simulator event run in the Gateway." --- # system.secsgem.startSimEventRun > Starts a configured simulator event run in the Gateway. This function is used in **Python Scripting**. ## Description Starts a configured simulator event run in the Gateway. Note, that this function only works with the simulators that come included with the SECS/GEM module. The function will throw an exception if the specified Event Run cannot be started. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): SECS/GEM Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when called in the Gateway scope. ## Syntax `system.secsgem.startSimEventRun(simulatorName, eventRunName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `simulatorName` | The simulator that holds the configured event run. Will throw an exception if the specified simulator can't be found. String| `eventRunName` | The event run to start. Will throw an exception if the specified simulator can't be found. ### Returns None ### Scope Gateway, Designer, Client ## Code Examples ```python title="Code Snippet" # This examples requires that the Gateway has a simulator named "simulator1", and # an Event Run in that same simulator named "myEventRun". mySimulator = "simulator1" eventRun = "myEventRun" system.secsgem.startSimEventRun(mySimulator, eventRun) ```
