--- title: "system.opchda.readAttributes" description: "Reads the specified attributes for the given item over a time range." --- # system.opchda.readAttributes > Reads the specified attributes for the given item over a time range. This function is used in **Python Scripting**. ## Description Reads the specified attributes for the given item over a time range. Attributes and their IDs are defined in the OPC-HDA specification, and can be discovered by calling [system.opchda.getAttributes()](appendix\scripting-functions\system-opchda\system-opchda-getAttributes.md). ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.opchda.readAttributes(serverName, itemId, attributeIds, startDate, endDate)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`serverName` | The name of the defined OPC-HDA server to read.| |String |`itemId` | The itemID to retrieve attributes for.| |String |`attributeIds` | The integer IDs of the attributes to read. The attribute ids are defined in the OPC-HDA specification. The attributes can also be obtained by calling system.opchda.getAttributes(). Some servers may not support all attributes.| |String| `startDate` | The starting date/time of the query.| |String |`endDate` | The ending date/time of the query.| ### Returns **ReadResults[]** - A list of read results which is one-to-one with the requested attributes. The ReadResult object has a `serviceResult` quality property that indicates whether the call was successful, and is itself a list of QualifiedValues. ### Scope All
