--- title: "system.opchda.insert" description: "Insert values on the OPC-HDA server if the given item ID does not exist." --- # system.opchda.insert > Insert values on the OPC-HDA server if the given item ID does not exist. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opchda.insert(serverName, itemId, value, date, quality)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`serverName` | The name of the defined OPC-HDA server.| |String| `itemId`| The item ID to perform the operation on.| |Object |`value` |The value to insert.| |Object|`date`| The date to insert.| |int |`quality`| The quality to insert.| ### Returns **QualityCode** - The result of the insert. ### Scope All ## Code Examples ```python title="Example #1" # This will insert the value for May 28th, 2014 at 5:42:33. date = system.date.getDate(2014, 4, 28) datetime = system.date.setTime(date, 5, 42, 33) system.opchda.insert("MyHistoryServer", "MyItemId", 42.5, datetime, 192) ```
