--- title: "system.opc.writeValue" description: "Writes a value directly through an OPC server connection synchronously." --- # system.opc.writeValue > Writes a value directly through an OPC server connection synchronously. This function is used in **Python Scripting**. ## Description Writes a value directly through an OPC server connection synchronously. Will return an OPC-UA status code object. You can quickly check if the write succeeded by calling isGood() on the return value from this function. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opc.writeValue(opcServer, itemPath, value)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`opcServer` |The name of the OPC server connection in which the item resides.| |String |`itemPath`| The item path, or address, to write to.| |Object |`value`| The value to write to the OPC item.| ### Returns **Quality** - The status of the write. Use returnValue.isGood() to check if the write succeeded. ### Scope All ## Code Examples ```python title="Code Snippet" server = "Ignition OPC-UA Server" path = "[SLCSim]_Meta:N7/N7:0" oldQualifiedValue = system.opc.readValue(server, path) newValue = oldQualifiedValue.getValue() + 1 returnQuality = system.opc.writeValue(server, path, newValue) if returnQuality.isGood(): print "Write was successful" else: print "Write failed" ```
