--- title: "system.opc.setServerEnabled" description: "Enables or disables an OPC server connection." --- # system.opc.setServerEnabled > Enables or disables an OPC server connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opc.setServerEnabled(serverName, enabled)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`serverName`| The name of an OPC server connection.| |Boolean| `enabled` | The new state the connection should be set to: true to enable the connection, false to disable.| ### Returns Nothing ### Scope All ## Code Examples ```python title="Code Snippet" # The following will iterate through all configured OPC servers, and check if they are enabled or disabled # If a OPC server is disabled, the code will enable it with a call to setServerEnabled # This code interacts in the client scope, so it should be placed on a component, such as a Button. # Retrieve a list of all servers in the gateway allServers = system.opc.getServers() # Initialize a message. The empty string is initially used so that the value may be checked later. message = "" # Iterate through each server. for server in allServers: # for each server, call isServerEnabled. Uses Python's "not" operator to check if a False value is returned. if not system.opc.isServerEnabled(server): # If disabled, then enable the server system.opc.setServerEnabled(server, True) # append details about the state change we made to the message variable message += "%s \n" % (server) # Check to see if any changes were made. If the length (len()) of the message is less than 1 character, then a change wasn't made. if len(message) < 1: # Notify the user that the code did not make any changes system.gui.messageBox("No servers were modified") else: # Otherwise, let the user know which servers we enabled. system.gui.messageBox("The following servers were modified:\n" + message) ```
