--- title: "system.opc.browseServer" description: "When called from a Vision Client, returns a list of OPCBrowseElement objects for the given server." --- # system.opc.browseServer > When called from a Vision Client, returns a list of OPCBrowseElement objects for the given server. This function is used in **Python Scripting**. ## Description When called from a Vision Client, returns a list of OPCBrowseElement objects for the given server. Otherwise returns a list of OPCBrowseElements. The OPCBrowseElement object has the following methods: - getDisplayName() - returns the display name of the object - getElementType() - returns the element type. Element types are server, device, view, folder, object, datavariable, property and method. - getNodeId() - returns a string representing the server node ID The PyOPCTag object has the following methods to retrieve information: - getDisplayName() - returns the display name of the object - getElementType() - returns the element type. Element types are server, device, view, folder, object, datavariable, property and method. - getServerName() - returns the server name as a string. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.opc.browseServer(opcServer, nodeId)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`opcServer` | The name of the OPC server connection.| |String| `nodeId` |The node ID to browse.| ### Returns **List** - A list of PyOPCTag objects. ### Scope Gateway ## Syntax - Vision Client Scope `system.opc.browseServer(opcServer, nodeId)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`opcServer` | The name of the OPC server connection.| |String |`nodeId`| The node ID to browse.| ### Returns **List** - A list of OPCBrowseElement objects. ### Scope Client ## Code Examples ```python title="Code Snippet" # Print the name of all devices on Ignition OPC-UA opcServer="Ignition OPC-UA Server" nodeId = "Devices" devices = system.opc.browseServer(opcServer, nodeId) for device in devices: print device.getDisplayName() ```
