--- title: "system.net.sendEmail" description: "Sends an email through the given SMTP server." --- # system.net.sendEmail > Sends an email through the given SMTP server. This function is used in **Python Scripting**. ## Description Sends an email through the given SMTP server. Note that this email is relayed first through the Gateway - the client host machine doesn't need network access to the SMTP server. You can send text messages to cell phones and pagers using email. Contact your cell carrier for details. If you had a Verizon cell phone with phone number (123) 555-8383, for example, your text messaging email address would be: 1235558383@vtext.com. Try it out! ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax :::tip This function accepts [keyword arguments](scripting/python-scripting/user-defined-functions.md#keyword-arguments). ::: `system.net.sendEmail(smtp, fromAddr, subject, body, html, to, attachmentNames, attachmentData, timeout, username, password, priority, smtpProfile, cc, bcc, retries)` Some of these parameters are new! ### Parameters |Type|Parameter|Description| |--|--|--| |String| `smtp` | The address of an SMTP server to send the email through, like "mail.example.com". A port can be specified, like "mail.example.com:25". SSL can also be forced, like "mail.example.com:25:tls".| |String |`fromAddr` | An email address to have the email come from.| |String |`subject` | The subject line for the email.| |String |`body` | The body text of the email.| |Boolean |`html` | A flag indicating whether or not to send the email as an HTML email. Will auto-detect if omitted.| |String[]| `to` | A list of email addresses to send to.| |String[] |`attachmentNames` | A list of attachment names. Attachment names must have the correct extension for the file type or an error will occur.| |byte[][]| `attachmentData` | A list of attachment data, in binary format.| |Integer| `timeout` | A timeout for the email, specified in milliseconds. Defaults to 300,000 milliseconds (5 minutes). | |String |`username` | If specified, will be used to authenticate with the SMTP host.| |String| `password` | If specified, will be used to authenticate with the SMTP host.| |String |`priority` | Priority for the message, from "1" to "5", with "1" being highest priority. Defaults to "3" (normal) priority.| |String |`smtpProfile` | If specified, the named SMTP profile defined in the Gateway will be used. If this keyword is present, the smtp, username, and password keywords will be ignored.| |String[] |`cc` | A list of email addresses to carbon copy. Only available if a smtpProfile is used.| |String[]| `bcc` | A list of email addresses to blind carbon copy. Only available if a smtpProfile is used.| |Integer|`retries`| The number of additional times to retry sending on failure. Defaults to 0. Only available if a smtpProfile is used.| |String[]| `replyTo` | An optional list of addresses to have the recipients reply to. If omitted, this defaults to the from address.| ### Returns Nothing ### Scope All ## Code Examples ```python title="Code Snippet" # This code would send a simple plain-text email to a single recipient, with no attachments body = "Hello, this is an email." recipients = ["bobsmith@mycompany.com"] system.net.sendEmail("mail.mycompany.com", "myemail@mycompany.com", "Here is the email!", body, 0, recipients) ``` ```python title="Code Snippet" # This code would send an HTML-formatted email to multiple recipients (including # cellphones) with no attachments body = "
