--- title: "system.net.openURL" description: "Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate." --- # system.net.openURL > Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate. This function is used in **Python Scripting**. ## Description Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate. For example, the URL: "http://www.google.com" ... will open in the default web browser, whereas this one: "file://C:/Report.pdf" ... will likely open in Adobe Acrobat. The Windows network-share style path like: "\\Fileserver\resources\machine_manual.pdf" ... will work as well (in Windows). Be careful not to use this function in a full-screen client, as launching an external program will break your full-screen exclusive mode. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.net.openURL(url [, useApplet])` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `url` | The URL to open in a web browser.| |boolean |`useApplet` | If set to true (1), and the client is running as an Applet, then the browser instance that launched the applet will be used to open the URL. [optional]| ### Returns Nothing ### Scope Client ## Code Examples ```python title="Code Snippet" # This code would open a web page system.net.openURL("http://www.google.com") ``` ```python title="Code Snippet" # This code would open a PDF document located at C: on the client computer # Note the double backslashes are needed because backslash is the escape character # for Python system.net.openURL("file://C:\\myPDF.pdf") ``` ```python title="Code Snippet" # This code would open a PDF document from a Windows-based file server # Note the double backslashes are needed because backslash is the escape character # for Python system.net.openURL("\\\\MyServer\\MyDocs\\document.pdf") ```
