--- title: "system.net.httpDelete" description: "Performs an HTTP DELETE to the given URL." --- # system.net.httpDelete > Performs an HTTP DELETE to the given URL. This function is used in **Python Scripting**. ## Description Keep in mind that JRE proxy settings will influence how these functions conduct their network activities. When using a non-bundled JRE, this is typically set via the Java Control Panel. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax :::tip This function accepts [keyword arguments](scripting/python-scripting/user-defined-functions.md#keyword-arguments). ::: `system.net.httpDelete(url, [contentType], [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`url` | The URL to send the request to.| |String |`contentType` | [Optional] The MIME type used in the HTTP 'Content-type' header.| |Int| `connectTimeout`|[Optional] The timeout for connecting to the URL in milliseconds. Default is 10,000| |Int |`readTimeout` | [Optional] The read timeout for the operation in milliseconds. Default is 60,000.| |String| `username` | [Optional] If specified, the call will attempt to authenticate with basic HTTP authentication.| |String |`password` | [Optional] The password used for basic HTTP authentication, if the username parameter is also present.| |PyDictionary |`headerValues` | [Optional] A dictionary of name/value pairs that will be set in the HTTP header.| |Boolean |`bypassCertValidation` | [Optional] If the target address in an HTTPS address, and this parameter is TRUE, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates.| ### Returns **Object** - The content returned for the DELETE operation. ### Scope All ## Code Example ```python title="Code Snippet" # This example attempts to perform a DELETE operation URL = "http://myURL/folder.resource" system.net.httpDelete(URL) ```
