--- title: "system.nav.openWindow" description: "Opens the window with the given path." --- # system.nav.openWindow > Opens the window with the given path. This function is used in **Python Scripting**. ## Description Opens the window with the given path. If the window is already open, brings it to the front. The optional params dictionary contains key:value pairs which will be used to set the target window's root container's dynamic variables. For instance, if the window that you are opening is named "TankDisplay" has a dynamic variable in its root container named "TankNumber", then calling `system.nav.openWindow("TankDisplay", {"TankNumber" : 4})` will open the "TankDisplay" window and set Root Container.TankNumber to four. This is useful for making parameterized windows, that is, windows that are re-used to display information about like pieces of equipment. See also: [Parameterized Popup Windows](visualization-and-dashboards\windows\popup-windows\parameterized-popup-window\parameterized-popup-window.md). ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.nav.openWindow(path [, params])` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `path` | The path to the window to open.| |PyDictionary| `params` |A dictionary of parameters to pass into the window. The keys in the dictionary must match dynamic property names on the target window's root container. The values for each key will be used to set those properties. [optional]| ### Returns **PyObject** - A reference to the opened window. ### Scope Client ## Code Examples ```python title="Code Snippet" # This is the simplest form of openWindow system.nav.openWindow("SomeWindowName") ``` ```python title="Code Snippet" # A more complex example - a setpoint screen for multiple valves that opens centered titleText = "Third Valve Setpoints" tankNo = system.nav.openWindow("ValveSetPts", {"valveNum":3, "titleText":titleText}) system.nav.centerWindow("ValveSetPts") ```
