--- title: "system.nav.desktop" description: "Allows for invoking system.nav functions on a specific desktop." --- # system.nav.desktop > Allows for invoking system.nav functions on a specific desktop. This function is used in **Python Scripting**. ## Description See the [Multi-Monitor Clients](clients\multi-monitor-clients.md) page for more details. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.nav.desktop(handle)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `handle` |The handle for the desktop to use. The screen index casted as a string may be used instead of the handle. If omitted, this will default to the Primary Desktop. Alternatively, the handle "primary" can be used to refer to the Primary Desktop.| ### Returns **INavUtilities** - A copy of system.nav that will atler the desktop named by the given handle. ### Scope Client ## Code Examples ```python title="Code Snippet" # The following example will close a window at path "Main Windows/Overview" in the Primary Desktop, # regardless of where the script originates from. system.nav.desktop().closeWindow("Main Windows/Overview") ``` ```python title="Code Snippet" # Attempts to swap to a window at path "Main Windows/Main Window" on a specific Desktop. This example assumes a desktop with the handle "2nd Desktop" is already open. system.nav.desktop("2nd Desktop").swapTo("Main Windows/Main Window") ```
