--- title: "system.gui.warningBox" description: "Displays a message to the user in a warning style pop-up dialog." --- # system.gui.warningBox > Displays a message to the user in a warning style pop-up dialog. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.gui.warningBox(message [, title])` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`message`|The message to display in the warning box. Will accept html formatting.| |String |`title` | The title for the warning box. [optional]| ### Returns Nothing ### Scope Client ## Code Examples ```python title="Example #1" # This code show a yellow popup box similar to the system.gui.messageBox function. # Start the motor, or, warn the user if in wrong mode runMode = event.source.parent.getPropertyValue('RunMode') # Cannot start the motor in mode #1 if runMode == 1: system.gui.warningBox("Cannot start the motor, current mode is VIEW MODE") else: system.db.runUpdateQuery("UPDATE MotorControl SET MotorRun=1") ```
