--- title: "system.gui.getQuality" description: "Returns the data quality for the property of the given component as an integer." --- # system.gui.getQuality > Returns the data quality for the property of the given component as an integer. This function is used in **Python Scripting**. ## Description Returns the data quality for the property of the given component as an integer. This function can be used to check the quality of a Tag binding on a component in the middle of the script so that alternative actions can be taken in the event of device disconnections. A description of the quality codes can be found on the [Tag Quality and Overlays](tags\understanding-tags\tag-quality-and-overlays.md) page. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.gui.getQuality(component, propertyName)` ### Parameters |Type|Parameter|Description| |--|--|--| |JComponent| `component` | The component whose property is being checked.| |String |`propertyName` | The name of the property as a string value.| ### Returns **int** - The data quality of the given property as an integer. ### Scope Client ## Code Examples ```python title="Example #1" # The following code checks the quality code on an component. If a quality is anything other than good, a message appears. # Fetch the quality code from the Value property on a Numeric Label. The Numeric Label is this example is inside the same container as this script. qualityCode = system.gui.getQuality(event.source.parent.getComponent('Numeric Label'), "value") # Evaluate the quality code. If a value other than 192 is returned... if qualityCode != 192: # ...then show a message informing the user. Using Python's string formatting (%i) to pass the quality code into the message. system.gui.messageBox("Operation Aborted \n The associated tag is showing quality code %i \n Please check the device connection") else: # The quality code is good, so continue working. This example simply shows a message, but could be modified to do something more meaningful system.gui.messageBox("The property is showing good quality") ```
