--- title: "system.gui.color" description: "Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly." --- # system.gui.color > Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly. This function is used in **Python Scripting**. ## Description Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly. See [toColor](appendix\expression-functions\type-casting\toColor.md) to see a list of available color names. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax (String) `system.gui.color(color)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`color` | A string that will be coerced into a color. Can accept many formats, such as "red" or "#FF0000" or "255,0,0".| ### Returns **Color** - The newly created color. ### Scope Client ## Syntax (int) `system.gui.color(red, green, blue [, alpha])` ### Parameters |Type|Parameter|Description| |--|--|--| |int| `red` | The red component of the color, an integer 0-255.| |int |`green` | The green component of the color, an integer 0-255.| |int |`blue` | The blue component of the color, an integer 0-255.| |int |`alpha`| The alpha component of the color, an integer 0-255. [optional]| ### Returns **Color** - The newly created color. ### Scope Client ## Code Examples ```python title="Example #1" # This example changes the background color of a component to red. myComponent = event.source myComponent.background = system.gui.color(255,0,0) # turn the component red ```
