--- title: "system.file.saveFile" description: "Prompts the user to save a new file named filename." --- # system.file.saveFile > Prompts the user to save a new file named filename. This function is used in **Python Scripting**. ## Description Prompts the user to save a new file named filename. The optional extension and typeDesc arguments can be added to be used as a type filter. If the user accepts the save, the path to that file will be returned. If the user cancels the save, None will be returned. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax #1 `system.file.saveFile(filename)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `filename` | A file name to suggest to the user. | ### Returns **String** - The path to the file that the user decided to save to, or None if they canceled. ### Scope Client ## Syntax #2 `system.file.saveFile(filename , extension , typeDesc)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `filename` | A file name to suggest to the user. | | String | `extension` | The appropriate file extension, like "jpeg", for the file. | | String | `typeDesc` | A description of the extension, like "JPEG Image". | ### Returns **String** - The path to the file that the user decided to save to, or None if they canceled. ### Scope Client ## Code Examples ```python title="Example #1" # This code would prompt the user to save the text in a text area to a file. path = system.file.saveFile("myfile.txt") if path is not None: system.file.writeFile(path, event.source.parent.getComponent("Text Area").text) ```
