--- title: "system.file.readFileAsString" description: "Opens the file found at path filename, and reads the entire file. Returns the file as a string." --- # system.file.readFileAsString > Opens the file found at path filename, and reads the entire file. Returns the file as a string. This function is used in **Python Scripting**. ## Description Opens the file found at path filename, and reads the entire file. Returns the file as a string. Common things to do with this string would be to load it into the text property of a component, upload it to a database table, or save it to another file using system.file.writeFile function. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.file.readFileAsString(filepath, encoding)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `filepath` | The path of the file to read. | | String | `encoding` | The character encoding of the file to be read. Will throw an exception if the string does not represent a supported - encoding. Common encodings are "UTF-8", "ISO-8859-1" and "US-ASCII". [Optional] | ### Returns **String** - The contents of the file as a string. ### Scope All ## Code Examples ```python title="Example #1" # This code would prompt the user to choose a text file. If the user chooses a file, it would then set a text area on the screen to display the file. path = system.file.openFile("txt") if path != None: contents = system.file.readFileAsString(path) event.source.parent.getComponent("Text Area").text = contents ```
