--- title: "system.dnp3.directOperateBinary" description: "Issues a Direct-Operate command for digital control operations at binary output points (CROB)." --- # system.dnp3.directOperateBinary > Issues a Direct-Operate command for digital control operations at binary output points (CROB). This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): DNP3 Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.dnp3.directOperateBinary(deviceName, indexes, opType, tcCode, count, onTime, offTime)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `deviceName` | The name of the DNP3 device driver. | | List | `indexes` | A list of indexes of the objects to be modified in the outstation. | | Integer | `opType` | The type of the operation. 0=NUL, 1=PULSE_ON, 2=PULSE_OFF, 3=LATCH_ON, 4=LATCH_OFF | | Integer | `tcCode` | The Trip-Close code, used in conjunction with the opType. 0=NUL, 1=CLOSE, 2=TRIP | | Integer | `count` | The number of times the outstation shall execute the operation. | | Long | `onTime` | The duration that the output drive remains active, in millis. | | Long | `offTime` | The duration that the output drive remains non-active, in millis. | ### Returns The DNP3 status code of the response, as an integer. ### Scope All ## Code Examples ```python title="Example #1" # This example shows latching off 3 binary output points with the Direct-Operate command. off = system.dnp3.LATCH_OFF system.dnp3.directOperateBinary("Dnp3", [0, 1, 2], off) ``` ```python title="Example #2" # This example shows setting a binary output point at index 3 to pulse at 5 second intervals # with the Direct-Operate command. pulse = system.dnp3.PULSE_OFF trip = system.dnp3.TRIP system.dnp3.directOperateBinary("Dnp3", [3], pulse, trip, onTime=5000, offTime=5000) ```
