--- title: "system.dnp3.directOperateAnalog" description: "Issues a Select-And-Operate command to set an analog value in an analog output point." --- # system.dnp3.directOperateAnalog > Issues a Select-And-Operate command to set an analog value in an analog output point. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): DNP3 Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.dnp3.directOperateAnalog(deviceName, index, value, [variation])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `deviceName` | The name of the DNP3 device driver. | | Integer | `index` | The index of the object to be modified in the outstation. | | Numeric | `value` | The analog value that is requested (of type int, short, float, or double). | | Integer | `variation` | The DNP3 object variation to use in the request. | ### Returns The DNP3 status code of the response, as an integer. ### Scope All ## Code Examples ```python title="Example #1" # This example shows setting the analog output at index 0 to the # Double value 3.14 system.dnp3.directOperateAnalog("Dnp3", 0, 3.14) ``` ```python title="Example #2" # This example shows setting the analog output at index 2 to the # Integer value 300 system.dnp3.directOperateAnalog("Dnp3", 2, 300) ``` ```python title="Example #3" # This example shows setting the analog output at index 15 to the # Short value 33. The value sent in the request is converted # for the object variation, 2. system.dnp3.directOperateAnalog("Dnp3", 15, 33.3333, variation=2) ``` ```python title="Example #4" # This example shows setting the analog output at index 1 to the # Float value 15.0. The value sent in the request is converted # for the object variation, 3. system.dnp3.directOperateAnalog("Dnp3", index=1, value=15, variation=3) ```
