--- title: "system.device.setDeviceHostname" description: "Changes the hostname of a device." --- # system.device.setDeviceHostname > Changes the hostname of a device. This function is used in **Python Scripting**. ## Description Changes the hostname of a device. Used for all ethernet based drivers. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Device Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.device.setDeviceHostname(deviceName, hostname)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `deviceName` | The name of the device in Ignition. | | String | `hostname` | The new IP address or hostname. | ### Returns Nothing ### Scope All ## Code Examples ```python title="Example 1" # Set Hostname: system.device.setDeviceHostname("CLX", "10.10.1.20") ```
