--- title: "system.device.addDevice" description: "Adds a new device connection in Ignition." --- # system.device.addDevice > Adds a new device connection in Ignition. This function is used in **Python Scripting**. ## Description Adds a new device connection in Ignition. Accepts a dictionary of parameters to configure the connection. Acceptable parameters differ by device type: i.e., a Modbus/TCP connection requires a hostname and port, but a simulator doesn't require any parameters. :::note When using this function, the arguments **MUST** be passed in as [keyword arguments](scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Device Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.device. addDevice(deviceType, deviceName, deviceProps)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `deviceType` | The device driver type. Possible values are listed in the Device Types table below. | | String | `deviceName` | The name that will be given to the the new device connection. | ### Returns Nothing ### Scope All ### Device Types :::note Note that this function may be called to add devices using 3rd party drivers: you simply need the driver type, which the module developer will be able to provide. ::: | Driver Name | Device Type | |---|---| | Legacy Allen-Bradley CompactLogix | CompactLogix | | Legacy Allen-Bradley ControlLogix | ControlLogix | | Simulators Dairy Demo Simulator | DairyDemoSimulator | | DNP3 Driver | Dnp3Driver | | Allen-Bradley Logix Driver | LogixDriver | | Allen-Bradley MicroLogix | MicroLogix | | Modbus RTU | ModbusRtuOverTcp | | Modbus TCP | ModbusTcp | | Omron NJ Driver | com.inductiveautomation.omron.NjDriver | | Allen-Bradley PLC5 | PLC5 | | Siemens S7-300 | S7300 | | Siemens S7-400 | S7400 | | Siemens S7-1200 | S71200 | | Siemens S7-1500 | S71500 | | Allen-Bradley SLC | SLC | | Simulators SLC Simulator | SLCSimulator | | Simulators Generic Simulator | Simulator | | TCP Driver | TCPDriver | | UDP Driver | UDPDriver | ### Device Properties The `deviceProps` parameter is where you supply configuration values to the new connection. Value properties depend on which deviceType was specified. A listing of deviceProps keys can be found on the [system.device.addDevice - deviceProps Listing](appendix\scripting-functions\system-device\system-device-addDevice\system-device-addDevice-deviceProps-Listing.md) page. The keys in the `deviceProps` parameter are **case-insensitive**. Device properties not specified in the deviceProps parameter will fallback to default values if not specified (where applicable: i.e., "hostname" typically does not have a default value). ## Code Examples ```python title="Example #1" # Below is an example of creating a new Generic Simulator device connection. # Note that we MUST pass a dictionary as the 3rd parameter, even if it's empty. # Call the function system.device.addDevice(deviceType = "Simulator", deviceName = "New_Generic_Simulator", deviceProps = {}) ``` ```python title="Example #2" # Add a device using the Allen-Bradley Logix Driver for firmware v21+ devices deviceProps = {} deviceProps["Hostname"] = "192.168.1.2" system.device.addDevice(deviceName="Test1", deviceType="LogixDriver", deviceProps=deviceProps) ``` ```python title="Example #3" # Below is an example of creating a new S7-1500 device connection. # Build a Dictionary of parameters newProps = { "HostName" : "10.0.0.1", "Port" : 102 # <---If adding additional parameters, make sure to add a comma. } # Call the function system.device.addDevice(deviceType = "S71500", \ deviceName = "My_S7_1500_Device",\ deviceProps = newProps) ```
