--- title: "system.db.runSFUpdateQuery" description: "Runs a query through the store and forward system and to multiple datasources at the same time." --- # system.db.runSFUpdateQuery > Runs a query through the store and forward system and to multiple datasources at the same time. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Legacy Database Access Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.runSFUpdateQuery(query, datasources)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `query` | A query (typically an UPDATE, INSERT, or DELETE) to run. String[] | `datasources` | List of datasources to run the query through. ### Returns **Boolean** - Returns true if successful and false if not. ### Scope All ## Code Examples ```python title="Example #1" # Example 1: Run through single datasource print system.db.runSFUpdateQuery("INSERT INTO recipes (name, sp1, sp2, sp3) VALUES ('A Name', 1032, 234, 1)", ["MySQLDatasource"]) ``` ```python title="Example #2" # Example 2: Run through 2 datasources print system.db.runSFUpdateQuery("INSERT INTO recipes (name, sp1, sp2, sp3) VALUES ('A Name', 1032, 234, 1)", ["MySQLDatasource", "SQLServerDatasource"]) ```
