--- title: "system.db.runNamedQuery" description: "Runs a named query and returns the results." --- # system.db.runNamedQuery > Runs a named query and returns the results. This function is used in **Python Scripting**. ## Description Runs a named query and returns the results. **Note** that the number of parameters in the function is determined by **scope**. Both versions of the function are listed below. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax (Client Scope) `system.db.runNamedQuery(path, parameters)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `path` | The path to the named query to run. Note that this is the full path to the query, including any folders. PyDictionary | `parameters` | A Python dictionary of parameters for the named query to use. ### Returns **Object** - The results of the query. The exact object returned depends on the Query Type property of the Named Query: typically either a dataset when set to **Query**, an integer representing the number of rows affected when set to **Update Query**, or an object matching the datatype of the value returned by a **Scalar Query**. ### Scope Client, Designer ## Syntax (Gateway Scope) `system.db.runNamedQuery(project, path, parameters)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `project` | The project name the query exists in. String | `path` | The path to the named query to run. Note that this is the full path to the query, including any folders. PyDictionary | `parameters` | A Python dictionary of parameters for the named query to use. ### Returns **Object** - The results of the query. The exact object returned depends on the Query Type property of the Named Query: typically either a dataset when set to **Query**, an integer representing the number of rows affected when set to **Update Query**, or an object matching the datatype of the value returned by a **Scalar Query**. ### Scope Gateway ## Code Examples ```python title="Example #1 - Without Parameters" # This example will run a Named Query without any parameters in the Project scope. # The second argument in the function is NOT optional, so named queries that do not require a parameter must still pass an empty dictionary as an argument. # Request the Named Query with an empty dictionary as the second parameter. system.db.runNamedQuery("folderName/myNamedQuery", {}) ``` ```python title="Example #2 - Gateway Scope" # This example will run a Named Query without any parameters in the Gateway scope. # The last argument in the function is NOT optional, so named queries that do not require a parameter must still pass an empty dictionary as an argument. # Request the Named Query to execute. system.db.runNamedQuery("ProjectName", "folderName/myNamedQuery", {}) ``` ```python title="Example #3 - With Parameters" # This example will run a Named Query while passing some parameters in the Project scope. # The Named Query is assumed to have two parameters already defined on the Named Query: # param1 : A string # param2 : An integer # Create a python dictionary of parameters to pass parameters = {"param1":"my string", "param2":10} # Run the Named Query system.db.runNamedQuery("myUpdateQuery", parameters) ```
