--- title: "system.db.refresh" description: "This function will programmatically cause a SQL Query or DB Browse property binding to execute immediately." --- # system.db.refresh > This function will programmatically cause a SQL Query or DB Browse property binding to execute immediately. This function is used in **Python Scripting**. ## Description This function will programmatically cause a [SQL Query](https://docs.inductiveautomation.com/display/DOC79/SQL+Query+Binding) or DB Browse property binding to execute immediately. This is most often used for bindings that are set to Polling - Off. In this way, you cause a binding to execute on demand, when you know that the results of its query will return a new result. To use it, you simply specify the component and name of the property on whose binding you'd like to refresh. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Legacy Database Access Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.refresh(component, propertyName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ JComponent | `component` | The component whose property you want to refresh String | `propertyName` | The name of the property that has a SQL Query binding that needs to be refreshed ### Returns **Boolean** - True (1) if the property was found and refreshed successfully. ### Scope All ## Code Examples ```python title="Example #1" # This example could be placed in the actionPerformed event of a Button, to be used to refresh the data of a Table. # Remember to use the scripting name of the property that you're trying to refresh, and that the property names are case-sensitive. table = event.source.parent.getComponent("Table") system.db.refresh(table, "data") ```
