--- title: "system.db.getConnectionInfo" description: "Returns a dataset of information about a single database connection, as specified by the name argument." --- # system.db.getConnectionInfo > Returns a dataset of information about a single database connection, as specified by the name argument. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.db.getConnectionInfo(name)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `name` | The name of the database connection to find information about. ### Returns **Dataset** - A dataset containing information about the named database connection, or an empty dataset if the connection wasn't found. ### Scope All ## Code Examples ```python title="Example #1" # This example checks the database connection type and selects a query format that matches. connectionInfo = system.db.getConnectionInfo() dbType = connectionInfo.getValueAt(0, "DBType") if dbType == "MYSQL": # mysql format for a column with a space in the name query = "SELECT `amps value` FROM pumps" else: # mssql format for a column with a space in the name query = "SELECT [amps value] FROM pumps" ```
