--- title: "system.db.execSProcCall" description: "Executes a stored procedure call." --- # system.db.execSProcCall > Executes a stored procedure call. This function is used in **Python Scripting**. ## Description Executes a stored procedure call. The one parameter to this function is an SProcCall - a stored procedure call context. See the description of [system.db.createSProcCall](https://docs.inductiveautomation.com/display/DOC79/system.db.createSProcCall) for more information and examples. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.db.execSProcCall(callContext)` ### Parameters Type | Parameter | Description ------- | ------- | ------ SProcCall | `callContext` | A stored procedure call context, with any input, output, and/or return value parameters correctly configured. Use system.db.createSProcCall to create a call context. ### Returns Nothing ### Scope All ## Code Examples There are no code examples available for this function.
