--- title: "system.db.dateFormat" description: "This function is used to format Dates nicely as strings." --- # system.db.dateFormat > This function is used to format Dates nicely as strings. This function is used in **Python Scripting**. ## Description This function is used to format Dates nicely as strings. It uses a format string to guide its formatting behavior. Learn more about date formatting in Dates Expert Tip: This function uses the Java class [java.text.SimpleDateFormat](https://docs.oracle.com/javase/1.5.0/docs/api/java/text/SimpleDateFormat.html) internally, and will accept any valid format string for that class. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.db.dateFormat(date, formatPattern)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Date | `date` | The Date object that you'd like to format String | `formatPattern` | A format pattern string to apply. ### Returns **String** - The date as a string formatted according to the format pattern. ### Scope All ## Code Examples ```python title="Example #1" # This example will display a message box on a button press that displays the selected date (without the time) # from a Calendar component, in a format like "Feb 3, 2009" date = event.source.parent.getComponent("Calendar").latchedDate toDisplay = system.db.dateFormat(date, "MMM d, yyyy") system.gui.messageBox("The date you selected is: %s" % toDisplay) ``` ```python title="Example #2" # This example would do the same as the one above, but also display the time, in a format like: "Feb 3, 2009 8:01pm" date = event.source.parent.getComponent("Calendar").latchedDate toDisplay = system.db.dateFormat(date, "MMM d, yyyy") system.gui.messageBox("The date you selected is: %s" % toDisplay) ``` ```python title="Example #3" # This example would take two dates from two Popup Calendar components, format them in a manner that the database understands, # and then use them in a SQL query to limit the results to a certain date range. startDate = event.source.parent.getComponent("StartDate").date endDate = event.source.parent.getComponent("EndDate").date startDate = system.db.dateFormat(startDate, "yyyy-MM-dd HH:mm:ss") endDate = system.db.dateFormat(endDate, "yyyy-MM-dd HH:mm:ss") query = ("SELECT * FROM mytable WHERE t_stamp >= '%s' AND t_stamp <= '%s'" % (startDate, endDate)) results = system.db.runQuery(query) event.source.parent.getComponent("Table").data = results ```
