--- title: "system.db.commitTransaction" description: "Performs a commit for the given transaction." --- # system.db.commitTransaction > Performs a commit for the given transaction. This function is used in **Python Scripting**. ## Description Performs a commit for the given transaction. This will make all statements executed against the transaction since its beginning or since the last commit or rollback take effect in the database. Until you commit a transaction, any changes that the transaction makes will not be visible to other connections. Note that if you are done with the transaction, you must close it after you commit it. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Legacy Database Access Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.commitTransaction(tx)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `tx` | The transaction ID. ### Returns Nothing ### Scope All ## Code Examples There are no code examples available for this function.
