--- title: "system.db.clearAllNamedQueryCaches" description: "This clears the caches of all Named Queries in a project." --- # system.db.clearAllNamedQueryCaches > This clears the caches of all Named Queries in a project. This function is used in **Python Scripting**. ## Description This clears the caches of all Named Queries in a project. If called from the Shared Scope (i.e., Tag Event Scripts, Alarm Pipelines, etc.) then the name of the project must be passed as a parameter. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax - Project Scope `system.db. clearAllNamedQueryCaches()` ### Parameters None ### Returns No Return Value ### Scope All ## Syntax - Shared Scope `system.db. clearAllNamedQueryCaches()` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `project` | The Project that contains the named query whose cache needs to be cleared. ### Returns No Return Value ### Scope All ## Code Examples ```python title="Example #1" # Calling this simply clears all Named Query Caches. # This is assumed to run in the Shared Scope, so the name of the project must be included. system.db.clearAllNamedQueryCaches("myProjectName") ``` ```python title="Example #2" # If multiple Named Queries with varying parameters are called in a single script, then clearAllNamedQueryCaches can be used to free up the memory used by all of the newly created caches. # This example is assumed to run in the Project Scope, so the project parameter may be omitted. # This creates one cache. params = {"param1":"A"} system.db.runNamedQuery("myUpdateQuery", params) # This creates a separate cache. params = {"param1":"B"} system.db.runNamedQuery("anotherUpdateQuery", params) # Clear all of the caches from the current project. Note that all caches are cleared, including those generated from elsewhere on the Gateway. system.db.clearAllNamedQueryCaches() ```
