--- title: "system.date.isDaylightTime" description: "Checks to see if the current timezone is using daylight savings time during the date specified." --- # system.date.isDaylightTime > Checks to see if the current timezone is using daylight savings time during the date specified. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.date.isDaylightTime([date])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Date | `date` | The date you want to check if the current timezone is observing daylight savings time. Uses now() if omitted. [optional] ### Returns **Bool** - True (1) if date is observing daylight savings time in the current timezone, false (0) otherwise. ### Scope All ## Code Examples ```python title="Example #1" date = system.date.getDate(2018, 6, 28) print system.date.isDaylightTime(date) #Will print True in the US Pacific Timezone. ```
