--- title: "system.dataset.setValue" description: "Takes a dataset and returns a new dataset with one value altered." --- # system.dataset.setValue > Takes a dataset and returns a new dataset with one value altered. This function is used in **Python Scripting**. ## Description Takes a dataset and returns a new dataset with one value altered. Datasets are immutable, so it is important to realize that this function does not actually set a value in the argument dataset. You'll need to do something with the new dataset that this function creates to achieve something useful. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax (columnName) `system.dataset.setValue(dataset, rowIndex, columnName, value)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Dataset | `dataset` | The starting dataset. Will not be modified (datasets are immutable), but acts as the basis for the returned dataset. int | `rowIndex` | The index of the row to set the value at (starting at 0) String | `columnName` | The name of the column to set the value at. Case insensitive. PyObject | `value` | The new value for the specified row/column. ### Returns **Dataset** - A new dataset, with the new value set at the given location. ### Scope All ## Syntax (columnIndex) `system.dataset.setValue(dataset, rowIndex, columnIndex, value)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Dataset | `dataset` | The starting dataset. Will not be modified (datasets are immutable), but acts as the basis for the returned dataset. int | `rowIndex` | The index of the row to set the value at (starting at 0) String | `columnIndex` | The index of the column to set the value at (starting at 0) PyObject | `value` | The new value for the specified row/column. ### Returns **Dataset** - A new dataset, with the new value set at the given location. ### Scope All ## Code Examples ```python title="Example 1" # This snippet could be used for a Button's actionPerformed event to change the selected cell's value in a Table component to zero. table = event.source.parent.getComponent("Table") selRow = table.getSelectedRow() selCol = table.getSelectedColumn() if selRow != -1 and selCol != -1: newData = system.dataset.setValue(table.data, selRow, selCol, 0.0) table.data = newData ```
