--- title: "system.dataset.exportExcel" description: "Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. " --- # system.dataset.exportExcel > Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. This function is used in **Python Scripting**. ## Description Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. Uses the same format as the dataSetToExcel function. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.dataset.exportExcel(filename, showHeaders, dataset[, nullsEmpty])` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `filename` | A suggested filename to save as. Boolean | `showHeaders` | If true (1), the spreadsheet will include a header row. Object[] | `dataset` | A sequence of datasets, one for each sheet in the resulting workbook. Boolean | `nullsEmpty` | If True (1), the spreadsheet will leave cells with NULL values empty, instead of allowing Excel to provide a default value like 0. Defaults to False. [Optional] ### Returns **String** - The path to the saved file, or None if the action was canceled by the user. ### Scope Client ## Code Examples ```python title="Example 1" # This snippet would prompt the user to save the data currently displayed in a Table component to an Excel-compatible spreadsheet file, and would open the file after a successful save. table = event.source.parent.getComponent("Table") filePath = system.dataset.exportExcel("data.xls", 1, table.data) if filePath != None: system.net.openURL("file://"+filePath) ```
