--- title: "system.dataset.dataSetToHTML" description: "Formats the contents of a dataset as an HTML page, returning the results as a string." --- # system.dataset.dataSetToHTML > Formats the contents of a dataset as an HTML page, returning the results as a string. This function is used in **Python Scripting**. ## Description Formats the contents of a dataset as an HTML page, returning the results as a string. Uses the < table > element to create a data table page. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.dataset.dataSetToHTML(showHeaders, dataset, title)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Boolean | `showHeaders` | If True (1), the spreadsheet will include a header row. Dataset | `datasets` | The dataset to export String | `title` | The title for the HTML page. ### Returns **String** - The HTML page as a string. ### Scope All ## Code Examples ```python title="Example 1" # This snippet would run a SQL query against a database, and turn the results into a string containing HTML. It then writes the string to a file on the local hard drive. results = system.db.runQuery("SELECT * FROM example1 LIMIT 100") results = system.dataset.toDataSet(results) html = system.dataset.dataSetToHTML(1, results, "Production Report") filePath = "C:\\output\\results.html" system.file.writeFile(filePath, html) ```
