--- title: "system.dataset.appendDataset" description: "Takes two different datasets and returns a new dataset with the second dataset appended to the first." --- # system.dataset.appendDataset > Takes two different datasets and returns a new dataset with the second dataset appended to the first. This function is used in **Python Scripting**. ## Description Takes two different datasets and returns a new dataset with the second dataset appended to the first. Will throw an error if the number and types of columns do not match. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.dataset.appendDataset(dataset1, dataset2)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Dataset | `dataset1` | The dataset that will come first in the returned dataset. Dataset | `dataset2` | The second dataset that will be appended to the end in the returned dataset. ### Returns **Dataset** - A new dataset that is a combination of the original two datasets. ### Scope All ## Code Examples ```python title="Example 1" # This example pulls in the datasets from two different table components, combines them, then writes the results to a third table. # the two source datasets must have the same number and types of columns. data1 = event.source.parent.getComponent('Table 1').data data2 = event.source.parent.getComponent('Table 2').data comboData = system.dataset.appendDataset(data1, data2) event.source.parent.getComponent('Table 3').data = comboData ```
