--- title: "Report Component - Rectangle Shape" description: "The Rectangle shape component creates a square or rectangle and can be used anywhere on a report." --- # Report Component - Rectangle Shape > The Rectangle shape component creates a square or rectangle and can be used anywhere on a report. ![](rectangleShape.png) **Component Palette Icon:** ![](rectangleIcon.png) ## Description The Rectangle shape component creates a square or rectangle and can be used anywhere on a report. Select the Rectangle shape on the Report Component Palette to make it active, and click and drag anywhere in your Report Designer to create a rectangle shape. Once the rectangle component is created, you can use the handles to change its height and width. Hold Shift while dragging to create a square instead of a rectangle. You can also change its stroke style, color, dash pattern, and much more. ## Properties ![](rectangleProps.png) | Property | Description | Category | |--- |--- |--- | | Fill | If true, the shape will fill its space with color. | Stroke and Fill | | Fill Color | If Fill is selected, the color that will fill the shape | Stroke and Fill | | Opacity | How opaque the fill color is, between 0 and 1. | Stroke and Fill | | Stroke Style | What style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md). | Stroke and Fill | | Stroke | [Details for the chosen stroke.](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md) Each Stroke has its own properties depending on the Stroke Style chosen. | Stroke and Fill | | Radius | Amount to radius the corners of this shape. | Rectangle Shape | | Roll | Number of degrees this shape is rotated clockwise. | Basic Properties | | Scale X | Amount to scale the width of this shape. 1 is scale to 100%. | Basic Properties | | Scale Y | Amount to scale the height of this shape. 1 is scale to 100%. | Basic Properties | | Visible | If true, the shape will be visible. | Basic Properties | | Width | Width of this shape in pixels. | Basic Properties | | Height | Height of this shape in pixels. | Basic Properties | | X | Horizontal distance in pixels between the left edge of this shape and the left edge of the page. | Basic Properties | | Y | Vertical distance in pixels between the upper edge of this shape and the top edge of the page. | Basic Properties | ## Example ![](rectangleExample.png) | Property | Value | |--- |--- | | Fill Color | Yellow | | Stroke Style | Double | | Stroke Color | Blue | | Stroke Inner Width | 3 pixels | | Stroke Outer Width | 10 pixels | | Stroke Position | Inner on path | | Stroke Separation | 5 pixels |
