--- title: "Report Component - Images" description: "The Image component lets you embed images into reports." --- # Report Component - Images > The Image component lets you embed images into reports. ![](image.png) **Component Palette Icon:** ![](image-palette.png) ## Description The Image component lets you [embed images into reports](reporting/report-design/images-in-reports/images-in-reports.md). Images can be dragged from a local computer, shared drive, webpage, or the Image Management Tool as files onto reports. They can also be pulled as binary data from a datasource. If no **Key** is associated with the image component, the dropped image will be used. If the **Key** does not link to a valid image, no image will be shown. The image displayed in the Report Designer is a placeholder. It will be replaced with the image associated with the image's **Key** when the report is generated or previewed. In the image component's **Property Inspector**, you can drag a [parameter](reporting/report-data/report-parameters.md) or a [datasource](reporting/report-data/report-data.md) column from the **Key Browser** into the **Key** field. The Data Key can resolve to a byte array, such as an image retrieved from a database, or a URL that points to an image on the web, or an image file on a disk. Remember that reports are generated on the Gateway, so the image source needs to be accessible from the Gateway computer. [Keychain Expressions](reporting/report-design/data-keys/keychain-expressions.md) can not be used in the data key, but the Key can be a parameter or datasource that dynamically constructs a path to an image. This allows you to easily change images in reports without changing the image component. ## Properties ![](Properties.png) | Property | Description | Category | |--- |--- |--- | | Fill | If true, the shape will fill its space with color. | Stroke and Fill | | Fill Selected | If fill is selected, the color that will fill the shape. | Stroke and Fill | | Opacity | How opaque the fill color is, between 0 and 1. | Stroke and Fill | | Stroke Style | What style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md). | Stroke and Fill | | Stroke | [Details for the chosen stroke.](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md) Each Stroke has its own properties depending on the Stroke Style chosen. | Stroke and Fill | | Grow to Fit | If true, rescale the original image to fit the shape. | Image Shape | | Key | Data Key for this image. | Image Shape | | Padding | Padding between the image and the shape's bounds. | Image Shape | | Page Index | For multi-page images, sets the page index to use. | Image Shape | | Preserve Aspect Ratio | If true, preserve the aspect ratio when resizing the image. | Image Shape | | Radius | The amount to radius the corners of this shape. | Rectangle Shape | | Roll | Number of degrees this shape is rotated clockwise. | Basic Properties | | Scale X | Amount to scale the width of this shape. 1 is scale to 100%. | Basic Properties | | Scale Y | Amount to scale the height of this shape. 1 is scale to 100%. | Basic Properties | | Visible | If true, the shape will be visible. | Basic Properties | | Width | Width of this shape in pixels. | Basic Properties | | Height | Height of this shape in pixels. | Basic Properties | | X | Horizontal distance in pixels between the left edge of this shape and the left edge of the page. | Basic Properties | | Y | Vertical distance in pixels between the top edge of this shape and the top edge of the page. | Basic Properties | ## Example ### Image in a Report ![](image-in-report.png) | Property | Value | |--- |--- | | Data Key | Image Path | The image in this report was created using a **Parameter** that resolved to a URL.
