--- title: "PDF Viewer Scripting Functions" --- # PDF Viewer Scripting Functions > * Parameters > * string **bytes** - The bytes of the PDF to be displayed on the component ## Scripting Functions ### .loadPDFBytes(bytes, name) * Description * This function will pass in the bytes of a PDF and load them into the PDF Viewer component. Please see Storing Files in a Database for more details * string **name** - The name of the PDF * Return * Nothing * Scope * Client ### .print(showDialog) * Description * This function will print the PDF. * Parameters * boolean **showDialog** - If true, shows the user a print dialog. Default is true [optional] * Return * Nothing * Scope * Client ### .setZoomFactor(zoom) * Description * This function will set the current zoom level of the PDF, adjusted to stay within the minimum / maximum zoom range. Will zoom in on center of page. * Parameters * float **zoom** - Zoom factor to use. 1.0 is no zoom. * Return * Nothing * Scope * Client ## Extension Functions This component does not have extension functions associated with it.
