--- title: "Progress Bar" description: "Visually indicates the progress of some task. Can be used to display any value that has an upper and lower bound." --- # Progress Bar > Visually indicates the progress of some task. Can be used to display any value that has an upper and lower bound. ![](ProgressBar0.png) **Component Palette Icon** ![](ProgressBar1.png) ## Properties |Name|Description|Property Type|Scripting|Category| |:---|:---|:---|:---|:---| |Antialias|Draw with antialias on? Makes text smoother.|boolean|.antialias|Appearance| |Background Color|The background color of the component.|Color|.background|Appearance| |Border|The border surrounding this component. NOTE that the border is unaffected by rotation.|Border|.border|Common| |Cursor|The mouse cursor to use when hovering over this component.|int|.cursorCode|Common| |Data Quality|The data quality code for any tag bindings on this component.|int|.dataQuality|Data| |Direction|Determines the direction of progress for this progress bar.|int|.direction|Appearance| |Enabled|If disabled, a component cannot be used.|boolean|.componentEnabled|Common| |Font|Font of text on this component.|Font|.font|Appearance| |Foreground Color|The foreground color of the component.|Color|.foreground|Appearance| |Horizontal?|If true, the progress bar will display horizontally, else it will display vertically.|boolean|.horizontal|Appearance| |Indeterminate?|When true, the progressbar displays animation indicating that something is happening, but it will take an indeterminate amount of time|boolean|.indeterminate|Behavior| |Maximum|The maximum value that this progress bar will reach.|int|.maximum|Data| |Minimum|The minimum value that this progress bar will reach.|int|.minimum|Data| |Mouseover Text|The text that is displayed in the tooltip which pops up on mouseover of this component.|String|.toolTipText|Common| |Name|The name of this component.|String|.name|Common| |Show Percentage?|If true, the progress bar will display its percentage.|boolean|.stringPainted|Appearance| |Styles|Contains the component's styles.|Dataset|.styles|Appearance| |Value|The current state of the Progress Bar.|int|.value|Data| |Visible|If disabled, the component will be hidden.|boolean|.visible|Common| ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) + [Style Customizer](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md#style-customizer) ## Examples #### Horizontal Blue Progress Bar ![](ProgressBar2.png) |Property Name|Value| |:---|:---| |Border|Titled Border| |Value|85| |Foreground Color|0,0,255| |Horizontal?|True| #### Wide Vertical Blue Progress Bar ![](ProgressBar3.png) |Property Name|Value| |:---|:---| |Border|Titled Border| |Value|85| |Foreground Color|0,0,255| |Horizontal?|False|
