--- title: "Moving Analog Indicator" description: "This component displays an analog value in context with other information about that value so that you can visually quickly see if the value is in the normal range or not." --- # Moving Analog Indicator > This component displays an analog value in context with other information about that value so that you can visually quickly see if the value is in the normal range or not. ![](mal0.png) **Component Palette Icon** ![](mal1.png) The Moving Analog Indicator is another component that fits well with the [High Performance HMI techniques and practices](visualization-and-dashboards\understanding-components\high-performance-hmi-techniques\high-performance-hmi-techniques.md). This component displays an analog value in context with other information about that value so that you can visually quickly see if the value is in the normal range or not. The current value is shown as an arrow pointing at a bar with segments showing the desired operating range, low and high alarm ranges, and interlock ranges. The Moving Analog Indicator component allows for extremely fast information delivery. At a glance, it is obvious to an operator whether or not the value is where it should be, or if it needs attention. If the value is in one of its alarm ranges, then that range changes color to get attention. To switch the Moving Analog Indicator between a horizontal vs vertical orientation, simply change the size so that it is either wide or tall, respectively. Typical setup of this component involves setting the ranges, and binding the Process Value property to a Tag's value. Some properties may be cleared out (null value) in order to disable them. For example, you may indicate where the current setpoint is by setting the Setpoint Value property. If you don't want to display the setpoint, simply clear this value out. ## Properties |Name|Description|Property Type|Scripting|Category| |:---|:---|:---|:---|:---| |Antialias|Draw with antialias on? Makes text smoother.|boolean|.antialias|Appearance| |Border|The border surrounding this component. NOTE that the border is unaffected by rotation.|Border|.border|Common| |Cursor|The mouse cursor to use when hovering over this component.|int|.cursorCode|Common| |Data Quality|The data quality code for any tag bindings on this component.|int|.dataQuality|Data| |Desired High|The upper value of the desired operating range.|Double|.desiredHi|Data| |Desired Low|The lower value of the desired operating range.|Double|.desiredLo|Data| |Desired Range Color|The color of the desired range.|Color|.desiredRangeColor|Appearance| |Hi Alarm Active|True when the process value is greater than the hi alarm threshold.|boolean|.hiAlarmActive|Data| |Hi Interlock Active|True when the process value is greater than the hi interlock threshold.|boolean|.hiInterlockActive|Data| |Hi-Hi Alarm Active|True when the process value is greater than the hi-hi alarm threshold.|boolean|.hihiAlarmActive|Data| |High Alarm|The value above which is a high alarm.|Double|.hiAlarm|Data| |High High Alarm|The value above which is a high-high alarm.|Double|.hihiAlarm|Data| |High Interlock|The value above which an interlock will be activated.|Double|.hiInterlock|Data| |Inactive Alarm Color|The color of inactive alarm range.|Color|.inactiveAlarmColor|Appearance| |Interlock Color|The color of the interlock range.|Color|.interlockColor|Appearance| |Level 1 Alarm Color|The color of an active level 1 alarm (Hi-Hi or Lo-Lo)|Color|.level1AlarmColor|Appearance| |Level 2 Alarm Color|The color of an active level 2 alarm (Hi or Lo).|Color|.level2AlarmColor|Appearance| |Lo Alarm Active|True when the process value is less than the lo alarm threshold.|boolean|.loAlarmActive|Data| |Lo Interlock Active|True when the process value is less than the lo interlock threshold.|boolean|.loInterlockActive|Data| |Lo-Lo Alarm Active|True when the process value is less than the lo-lo alarm threshold.|boolean|.loloAlarmActive|Data| |Low Alarm|The value below which is a low alarm.|Double|.loAlarm|Data| |Low Interlock|The value below which an interlock will be activated.|Double|.loInterlock|Data| |Low Low Alarm|The value below which is a low-low alarm.|Double|.loloAlarm|Data| |Mouseover Text|The text that is displayed in the tooltip which pops up on mouseover of this component.|String|.toolTipText|Common| |Name|The name of this component.|String|.name|Common| |Process Value|The current value of the process.|Double|.processValue|Data| |Range Fill|The background color of the range strip.|Color|.rangeFill|Appearance| |Range High|The overall high value for the display.|double|.rangeHi|Data| |Range Low|The overall low value for the display.|double|.rangeLo|Data| |Range Stroke|The stroke color for the range strip.|Color|.rangeStroke|Appearance| |Reverse Indicator|Put the indicator triangle on the other side of the track.|boolean|.reverseIndicatorLocation|Appearance| |Setpoint Fill|The fill color of the setpoint indicator.|Color|.setpointFill|Appearance| |Setpoint Stroke|The stroke color of the setpoint indicator.|Color|.setpointStroke|Appearance| |Setpoint Value|The current value of the setpoint.|Double|.setpointValue|Data| |Show Value|Show the current value above or beneath the value indicator.|boolean|.showValue|Appearance| |Stroke Width|The stroke width for lines drawn.|float|.strokeWidth|Appearance| |Styles|Contains the component's styles|Dataset|.styles|Appearance| |Value Font|The font for the value label.|Font|.font|Appearance| |Value Format|The string format for the value, if it is shown.|String|.valueFormat|Appearance| |Value Indicator Fill|The fill color of the value indicator.|Color|.valueFill|Appearance| |Value Indicator Stroke|The stroke color of the value indicator.|Color|.valueStroke|Appearance| |Visible|If disabled, the component will be hidden.|boolean|.visible|Common| ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md) + [Style Customizer](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md#style-customizer) ## Examples #### Moving Analog Indicator Expanded Horizontally ![](mal2.png) #### Stylized Moving Analog Indicator ![](mal3.png) |Property Name|Value| |:---|:---| |Show Value|True| |Reverse Indicator|True| |Stroke Width|0.0|
